Hello all I am new to this forum i am huge fan of forum and on the Sea Ray forum. So this may get long winded I will try keep it short but looking for advice.
have a 2001 Sea Ray 190BR with 5.0 EFI merc and alpha 1 leg. I have been having issues with the boat bogging no power on water it starts and idles fine but when I put hammer down it just Bogs. So far this week I have found a jelly like stuff in the fuel so in emptied the fuel tank cleaned it out it is very clean inside put on new fuel filter went out tried boat yesterday and it is almost worse it will start and idle fine but I could not get on plane topped out at 2200rpm when I just use the throttle it will rev right up sounds good to 5000rpm. I manage to get on plane once yesterday topped out at 4000rpm and then after could not get it on plane again same 2200rpm tops very shutter/vibration feel from engine no power. So after this got home I put a gauge in-line from fuel pump to the TBI and when start it got 32psi steady when boat is running idle and revs. So from what I have found 28-32psi is normal for this pump. So I am not sure now what to do or check. I looked at the distributor cap and looks fine as in no moisture but I am tempted to change cap and rotor out as it has been 6yrs since that was done and do the spark plugs as I have never changed them for the whole 8yrs I have owned This boat. What’s your thoughts fellas.
