How far did you get into the carbs, Straightup? Also. Did you replace all fuel lines to the carbs and clean out any gunk/particulates?
If you want to know the proper steps for rebuilding the carb you have, I highly recommend you buy a factory/OEM service manual and follow it.
It takes three key things for a proper carb rebuild:
1. Take it completely apart per OEM service manual, including the Welsh Plugs and re-assemble correctly per service manual. Buy a
geniune OMC/BRP carb rebuild kit with carb/intake manifold gaskets, not aftermarket. You take a significant gamble on many aftermarket marine carb rebuild kits.
2. Set the carb linkage correctly per OEM service manual for the link and sync procedure.
3. Verify the throttle cable linkage is set correct and you have the correct pre-load pressure to return the throttle arm back to its stop to minimum idle.
I'm having the same problem with my '84 Johnson 70 Looper.. Thank you for your post. - Jeff
I don't know why you'd be asking him right now Baker123, it looks like he's stuck where you are with his hands full.
Not to mention that's not even close to your model of engine.
