- Jul 18, 2011
- 19,151
Hello Everyone,
The starboard engine started acting up today on the way back to my home port after a day-long outing. It would not go into gear once in the harbor and at no-wake speeds. (Bravo 3 outdrive) We had to stop a few times for traffic in the channel, so I was in and out of gear a few times. Then after a while, nothing from the starboard engine. :facepalm:
If I tried to force it (which I did once) , the engine revs would pick up before it went into gear, causing a jolt when it finally engaged. It has done this a few times in the past year or so, but the problem then goes away.
I navigated to the dock on the port engine.
Upon leaving the dock, the starboard engine would now go into gear no problem, as if nothing had happened :noidea: . I'm assuming it is an adjustment and I probably need to get the adjustment tool, but I thought I would check in with the experts before I get in too deep.
Thoughts?
FWIW - I have the crappy Quicksilver controls . . . thinking of getting the high performance controls with separate shift and throttle levers . . .
Thoughts?
