boatingwithmyselfs
- Apr 30, 2012
- 5
I've been rebuilding the floor of my 1979 Webbcraft 18' Tri-hull and have reached a point where I have a few questions. I've read through tons of the stickies and other posts but have confused myself with the different recommendations for epoxy vs poly resin.
So far, I decided to use marine grade plywood and the West System epoxy (105-B and 206-B) for the floor. I cut out the old floor with a circular saw and found rock solid stringers wrapped in fiberglass, so I haven't messed with those other than to fill some holes with epoxy. The new floor received two coats of epoxy on the bottom and sides and then was screwed down to the stringers. All holes were pre-drilled to a diameter larger than the screws and filled with epoxy, then I pre-drilled the epoxy to a diameter smaller than the screws. The gaps between boards and between the hull and the floor have been filled with peanut butter made with a blend of epoxy and fumed silica. I bought and cut to size a roll of 1708 biaxial cloth for the tabs and floor.
So my questions:
1) If I understand other posts correctly, the epoxy will not dissolve the CSM on the bottom of the cloth the way that poly resin would. Is it okay to lay down the 1708 with epoxy or do I need to buy a different cloth?
2) Assuming I can use 1708, should I do the tabs first and then the floor, or the floor first and then the tabs?
3) Also assuming 1708 is okay, should I wet the floor with epoxy and then lay the 1708 over that, then add another layer or two of epoxy over the 1708? Do I need two layers of 1708?
4) When laying the 1708, do I overlap it or just butt it up to the last piece?
Thanks in advance for any help y'all can offer this newbie.
So my questions:
