Boat restoration 1989 Charger 1850
kcassells
Oh yea....you will want to save your livewell for any kind of storage. save it. Cut around it @2-3" and it goes back in and now has a flange.
Dude...you have a project. drink a beer, relax, it's not going anywhere so put it back righ and safe. :watermelon:
ChargerMan1
I cut the bottom pan out. After the deck is in, I used the resin and made fillets to raise the whole section so the windows align like they are supposed to
#301 on my resto project
My guess if you do it this way then you can get the whole bow easily? Compared to trying to do it around the middle part of the bow? And I have a board that runs along the bottom from the front of engine block to the bow. So this would make it super simple. So you have done this a while ago. How is it holding up today? The bow part you cut
Chris51280
Ensign
Its holding up just fine. It also has the advantage by not trying to get the floor level with the bottom of the "hallway" of the bow section. Once you cover it up with carpet if you want, you won't even see it. If you leave it and paint or gelcoat, then some sanding is involved. So, either you work around the obstacles before or have the work later where you won't be twisted into a pretzel trying to get it in there and work around this bow section. Choice is yours.
ChargerMan1
Ok, guess who made it to the bow! But as you can see on the pics I am not even sure where to go here. I mean is this enough and if not what did you use to get the rest?
Chris51280
Ensign
I cut out the bottom about 1/2" to 3/4" from the floor upper face. I got enough room to reach everything to get the stringers in. Then i started with the bow section of the floor. After the floor is in, thats when I supported the front sides and aligned the windows so they look symmetrical. Thats when I used PB and filled in the gap. Used fairing compound to smooth things over. Its up to you if you want to carpet or paint the floor then
Chris51280
Ensign
its hard to tell, but it looks to be ok to get to the stringers on the inside
Chris51280
Ensign
there is a set srew on the bottom angled in. I think its 1/8 or 3/16 allen wrench. take the middle knob out. just plastic snap to pull. take the phillips screw out and unhook the 4 color wires. then pull the handle. then you can see the screws behind the cover
kirkll
I'm not real experienced at restoring old glass boats, but i just replaced the shift control just like yours on my 1990 Blue Water, and your shift control handle only screws to that panel, It does not screw into the hull or blocking holding the panel in place. you will have to remove the whole panel, and disassemble the handle to remove it from the panel & disconnect the shift/throttle cables from the back side.
Look for hidden screws in the seam of the upholstery to get the panel loose. I had two hidden screws myself. Kirk
ChargerMan1
Jeez are you kidding me lol
ChargerMan1
Engine out! That was fun in 105 degree weather
ChargerMan1
This probably is a dumb question, but I am new at this so... should I take measurements of my engine mount? So that it will be easier to remount it when I'm done cleaning the boat out? Pulling the engine out was pretty simple, but it seems that it could be a pain to reinstall. So I'm guessing if I take those measurements and rebuild it the same way hopefully I will cut down on error. I noticed that the mounts were 4x4s right next to each other. Ill see more when i tear into them, but that's what it looks like.
Original Thor
When I took my boat apart i took measurements of everything I could. Mine is a outboard but so little different but the stern of the boat actually moved about a half a inch out so had to use a strap and pull it in while I tabbed it in and put PB along the bottom. Once it set up it held in place.
ChargerMan1
So, it looks like when they originally built this they used 4x4's. Is this the same way that I rebuild it once I get everything grinded and sanded down? Or is there a better way to do it?
AShipShow
Typically following what the manufacturer did is a safe bet, however, theres always room for improvement since they did what they could to meet the bare minimum requirements to keep costs down... 4x4s will work just fine... I decided to make my new engine mounts from plywood and through bolt them instead of lag screws... Definitely more work to glass in, but less likely to rot since any water can drain through the holes instead of sit there.
Same goes with floors, stringers, bulkheads, transoms, etc... put back what was there at a minimum, but don't be afraid to use something different or better... We'll tell you if its a good idea or not...
Typically exterior grade plywood is what most of us use for stringers, bulkheads, transoms, and floors cuz its readily available and significantly cheaper than "marine-grade" plywood, and basically the same stuff...
For now, worry about removing the rot and grinding down to clean glass...
Hopefully you're taking measurements of everything, more than you think you need, cuz you'll forget 3 months from now when you're putting stuff back together.
Good luck, stay cool, drink water (or coors light, same thing), and keep at it
ChargerMan1
Ok update. Got the whole back part out for the most part anyway. I have found a few things while I was doing it. There is a hole in the hull. The middle what part seems to be one whole composite piece that apparently needs to be ripped up...yay. the transom is solid at the top and middle. I was talking to my neighbor whom builds boats. Mostly sailboats. He said my transom is fine, but if I am worried about it I could reinforce it by putting 3/4 marine grade plywood over it. Probably use PL adhesive, glass it, and then he said to run bolts all the way through it to make sure I get complete squeeze out. I found that the wood that was next to the 4x4s were two heavy 2x6s. So could use something else that's lighter which would be good for the boat I'm guessing.
here is a video update of everything. If you want to see it.
Thanks again everyone for the pointers and help.
https://www.youtube.com/watch?v=FMKv...&feature=share
kcassells
Sounds like alot of smack ast suggestions from your boatbuilder buds. Replace the thing and forget about it.
