jonny rotten
- Jan 8, 2012
- 380
Trying to get the upper trim limit retaining bracket off to replace the senders. THe one that holds the wire bracket at transom. The lower one is easy and out. The upper one I cant get to. A regular open end wrench doesnt have the angle without hitting the gimble bearing housing and the gimble ring blocks the bolt for a socket. Its to tight for a swivel socket. A stubby wrench is to long also. Bellows are off and gimble housing is off and I still cant get to it.
The bolt appears to be to close to the the housing on one side and it doesnt seem as if the closed end of a wrench will have room to get around the bolt head or I would run out and get a swivel wrench set or off set wrench...but I dont think they would work either
Any tool or ticks to get that upper bolt out?
Mercruiser alpha one
