BajabossJD
- Jul 10, 2011
- 138
Hey guys,
A few weeks ago you all were helpful with a question on had while working on a friends boat. I installed a new 5.7 carb motor in place of a low compression 5.0 he had. I completed the job, installed all new exhaust with 3" spacers (dry joint). Boat ran great on the Sea Trial. Fast forward a week and customer takes it out.. Calls me saying its running rough and wouldn't restart after he got fuel. He said it cranked and cranked but wouldn't start.
I get it back in the shop and the dreaded spinning of the starter happened. I pulled started and plugs and tried to turn the engine over with studs on the balancer. Wouldn't move. I pulled the exhaust and saw a mess of Salt water in one manifold. I moved further down and saw this pic of the broken flapper.
I pulled the head and saw water in the cylinders. Removed the water, poured atf / acetone in each cylinder. Its been a day so far and the engine is still locked.
It was exactly one week since he said it wouldn't start ( I was out of town over the 4th).
At this point, I'm better off trying to hone the block and install new bearings and rings. Maybe the block will free up with another day or two of soaking?
This was a remanned long block by a reputable builder in Florida. Not his fault at all. Since I'm on the hook for this job... am I better off buying another long block or rebuilding the current unit that has maybe 3 hours on it? Hone block, clean up the head, install new Rings and bearings.. I have a few new completed gasket kits in stock.
Here's the pics. Bad luck for sure and this job continues to occupy my shop. My fault for not checking flappers. I was told all that stuff was new. I'll take ownership of it but I'd like to know if rebuilding the fresh block is smarter than dropping another $2k on a long block. These pics are 1 week after the failure, Salt water and 100 degree Florida temps... Ole' Iron doesn't like it.
I've rebuilt a few four strokes before ( mostly BRP and Yamaha Ski motors ) but never a hydro locked one.
Thanks,
Joe
Thanks,
Joe
