I have a '92 4.3 alpha one gen 2 with Thunderbolt 4. I bought the boat in the spring of '19 and used it last summer. The boat struggled to run up from 1500 RPM's and would hesitate and almost stall. If I pegged it to WOT it would sputter, maybe pop, and then run up to speed. I figured it was the accelerator pump, so I rebuilt the carburetor over the winter in addition to new cap, rotor, and plugs. I discovered the exhaust manifolds were cracked so I replaced those and did the risers and flappers at the same time. I ran the boat in the water for the first time yesterday and still have the issue. In fact, it feels a little worse than before and doesn't seem to have enough power once I get it going. At WOT it maxed out under 4K RPM's and the boat felt sluggish.
Any thoughts on what could be causing the issue?
