JLumbert
- Jul 20, 2020
- 10
I am new to boating and we bought a 84 Bayliner with a 67 Johnson. Issue is that it will run fine in a no wake zone all day and no overheating issues at all, then the moment after boating through the channel to get to the lake, it dies once i slowly go to WOT under load. It then wont start again and I have the embarrassment of getting towed in to the dock.
Ive spent hours looking for a solution. I tested the spark - good ! New ignition coil / wires. Tested the Fuel - no water and only use rec. fuel (non ethanol). Sea-Foamed the motor - check.
After I get it towed home, it wont start for a day or so. I sprayed some fuel down the carb and it'll start up after a few times doing that. It will run in a tank/barrel just fine. I can go WOT with no load (only do it once or twice). But once i get in the lake or channel under load, it dies under WOT with a load and cant be restarted with fuel down the carb or anything.
I will say that the 2 times it didn't die, it felt slightly under-powered and had difficulty getting up in the RPM's or on plane (got it on plane one time). I would say that it wouldn't go over 2500-3000 RPM under load also
I am extremely lost. Anyone have any ideas what can be an issue?
