Rockrunner99
- May 3, 2020
- 7
I have a 2002 Sea Ray 5.0 mercruiser that was low on gear oil. I filled the reserve reservoir to the top last week and ran it for maybe 30-40 minutes. When I checked yesterday the reservoir was nearly empty again. Can't see any obvious leaks and the bilge does not show enough oil in it, I used a full tube when I filled it. I pulled the boat out of the slip last night and it's on the hard now, I'll check to see if there is an oil drip/stain on the driveway when I get home.
Is there an area I should check first? any weak points in the system or gasket that goes bad? We bought the boat two months ago and it has worked great except for this problem and oil in the steering fluid (another post)
Any help is appreciated
Thanks Tom
2002 Sea Ray 200 select 5.0 EFI
Thanks Tom
