jonny rotten
- Jan 8, 2012
- 380
I just did the bellows Gimbal bearing and lower shift cable.
First time out going from forward to neutral was very difficult. Forward throttle seems harder than I remember it being. I didnt use reverse much but when I did I think was the same issue going into neutral.
I never stalled and there was no grinding of the gears.
When I installed the inner core of the lower shift cable it had some resistance but not much. I was thinking the resistance was coming the way the cable was curved around the engine. I used a chaser wire but cant be sure it's exactly the same route as it was before as I did it alone and had some issues.
The roller in the outdrive spun easily and I greased it.
I did the shifter cable adjustment by the book. 6 inches on the lower cable, adjusted the cable above it then 4 turns back, nut all the way down in the slot
In the driveway it goes into neutral easy
Why would throttle be stiff in gear and hard finding neutral with a new cable. Throttle out of gear rev's easy
1990 mercruiser Alpha one gen one
