Rubber mat is a good idea, I didnt think of that. My original idea was to only have drainage from the ski locker because that is the only under deck storage my boat has. The original stringers had 2 holes drilled halfway up the stringers in the bilge (I am assuming these were weep holes) but the way I looked at those was water can go in then never drain out because of the height of them.
I placed foam in my compartments in the entire boat with drainage holes. Then poured in expansion foam.
All gravity.![]()
Yeh, kcassells I was curious what the density of the gravity system foam was. I watched the youtube video and it looks very interesting. Just curious if the pour in foam would compress the drainage foam to the point it no longer sheds water? I guess I should have asked on your thread, but you were way past that point when I finally caught up with your build, :ranger:
1 Cor 15:1-4 GSPLures
I just caught this on your sign in/name whatever. As much as I like this thread I will not promote religious, political, personal
whatsoever.
I am off this thread, wishing you only the best. I respect your beliefs.
“Promoting“ his signature seems a bit of a stretch to me by simply following and commenting from time to time in a thread.I’m not even sure how that works to be honest. But I guess to each their own....
I’ll be around to help as much as you would like. I hope this doesn’t throw a wet blanket on your posting frequency, I really am enjoying this thread.
GSPLures, amazing progress! I will be following you closely as I'm just behind you in doing my own restore!
I made sure I had a crossmember adjacencies to my joints. I think that’s a great practice because it really makes the structure one piece, and solid.
I would not add one where the stringers end. It won’t really add anything in my opinion because of how thin it would have to be in order for the deck to lay on it. Bedding and tabbing the ends of the stringers will make it extremely solid.
Yeah, I still don’t think it’s necessary, just extra work as long as the deck is bonded to the stringers. Once the stringers are bonded to the hull, and the deck, they’re not going anywhere. Obviously adding additional structure doesn’t hurt anything, but in this case I’m not sure it would do anything. :noidea:
