Hurricane Jay
- Aug 5, 2020
- 21
I've been trying to adjust the throttle cable according to the installation book for my 3.0 L built in 1996. After increasing throttle past the forward detente position, then returning the control to idle position (straight up 12:00), the engine doesn't want to slow down to idle without manually forcing the linkage. The shaft of the cable pulls out a bit from the cable end guide when throttling up, causing the throttle not to close completely. Does this require a new throttle cable, or is there some other adjustment to be made?
