Back into boating
- Aug 6, 2020
- 3
I’ve got a 1990 Mercruiser 3.0, 115 hp, 4 cyl engine that won’t stay on. It turns over and then shuts off.
Just a few days ago, it was running, but running hot so we replaced the lower impeller, thermostat and water pump.
Now the tilt is stuck in the up position (no problem with that prior to today) and the engine shuts off immediately after turning on.
Any thoughts on where to go next?
Is it shutting off because the prop is up? Again, there was no indication that there was any problem with the tilt or trim until today. It just clicks, the pump does not turn on.
Thanks in advance!
Thanks in advance!
