jesse_boston
- Aug 2, 2020
- 78
Hi!
I just brought home a 1995 Doral 230 EX / Mercruiser 5.7 (carb... not sure which carb, with thunderbolt ignition), Alpha I Gen 2.
I was watching some videos to learn about maintenance on the outdrive and in one of the ones showing gear oil replacement, the guy had to lean against his drive to push it against the stops to be able to put enough pressure on the screwdriver to remove the drain and vent plugs.
I can't move my outdrive at all side to side when it is sitting on the trailer with the engine off... should I be able to?
Maybe something is over-torqued? Or Is this because I have power steering and maybe the boat in the video didn't have it?
Second question:
Any idea what the holes in this photo are for? Maybe someone put on a hydrofoil at one point and then took it back off?
Also, how quickly do I need to replace this cracked anode, and the missing cap on the tilt piston?
Thanks all!
Second question:
Thanks all!
