crashnburn98
- Aug 10, 2020
- 4
I have a 4.3 alpha one first gen with the mechanical fuel pump. Boat sat a few years. Got it running, new fluids and filters. Put the thing in the water wouldnt run. Rebuilt the carb and changed fuel pump. Ran good for a few hours than acted like low on gas. Had a half tank still. Checked the filter in tank and the siphon valve on tank all good. Switched to my 6 gallon in boat tank just for fun, no difference. Got a new carb, checked all filters, nothing in them but clean gas. New spark plugs. Thing seems good from tank to crab but won't open up under load above 3500 ram. Distibuter looked clean inside. Didn't move it just took cap off and used some 1000 grit to touch up the tips on cap carefully no difference. Wire to coil seems good. Gonna check timing with a timing light next, any other ideas?
