tommyboym7
- Aug 11, 2020
- 2
Hey guys, I'm new to this forum and new to boating as of last year but have an Issue driving me nuts with Bayliner 185 with Mercruiser 3.0 engine. Started late last season where boat starts and idles fine as well as revs up RPM fine while sitting. Then once in gear still runs fine but when pushing throttle while in gear to speed up it seems to starve the engine and sputter almost like i'm not getting enough fuel. It would then snap out of it after about 5 minutes of struggling while trying to get up to speed then run fine for the rest of the day. Then it started getting worse and wouldn't snap out of it. Now this year it's doing the same thing again and just struggles while in gear and trying to go faster than a few miles per hour and wants to cut out when giving gas while in gear but fine if in neutral and giving gas or just placing in drive and going very slowly.
Things i've done to try to fix: Additives (sea foam), drained gas and put fresh gas in (non-ethanol) (old gas been using in mower and runs fine), new plugs (several changes), new wires, new fuel filter, new distributor cap and rotar, cleaned carb, new carb fuel line filter, new carb float, new carb needle, checked fuel pickup screen and is clear. Not really sure where to go next with this maybe fuel pump replacement? Just seems like somethings blocking it from getting enough fuel or possibly an intake issue? Any ideas would be greatly appreciated!! All of these things have been done recently.
