1988 Force 50 507T8B high speed miss. Tried everything.
WalleyedNJ
I have a new to me 1988 Force 50, model 507T8B, with a high speed miss I can't diagnose.
This is what I've done so far:
Verified connectors all all stator/trigger wires are good
Verified stator and trigger resistance and voltage output with a DVA, all within normal range.
Set and verified timing (28 degrees BTDC at WOT)
Cleaned carburetor
Rebuilt fuel pump
replace all fuel lines and new primer bulb.
Fresh gas/oil mixture
new plugs
spark jumps a 7/16" gap with good color.
compression is 125 psi on both cylinders
removing stator charging wires from rectifier had no effect.
Running engine in garbage can:
Idle set at 1000rpm. Engine idles smoothly, no issues.
Slowing rev it up and it starts to misfire around 2600-2800 rpm.
I'm running out of things to check and I don't want to just start swapping parts.
Only slight oddity is the coil/cdi pack for cylinder 1 is the old style, cylinder 2 is the new style.
What's my next step?
Thanks,
Jim
WinnerCougar74
Double/triple check your fuel pump. I had a stumble that started at 2500rpms and a new fuel pump diaphragm fixed it. They seems to go bad very easily. Maybe the one you put in was bad.
WalleyedNJ
No blowback, no spitting, throttle plate parallel at WOT.
I have not pulled the reed assembly, I guess that's next.
The Force power
Cleaned carburetor
Rebuilt fuel pump
new plugs
Thanks,
Jim
Here's a link that will assist you with diagnosing the ignition;
https://www.outboardignition.com/page8.asp
jerryjerry05
They sell a "snake camera" for the new smart phones.
My Android, I bought a camera for 11$.and it works great.
Just hook it up and look at the reeds.
You can remove the carb or not??
Make sure you get the one with the firm/stiff cable.
WalleyedNJ
Yes, I can remove the carb, I've already had it off. I did a cursory look at the reeds at that time, but I need to inspect them further.
