The Force power
- Feb 3, 2019
- 2,358
Force power, The plugs are new and the spark test showed a good spark at 9/16". The Re-circ system test is next. I assume that consists of just spraying carb cleaner around all components and mating surfaces on intake related parts? Also, is there a preferred motor speed for trying the Re-circ test? Thanks.
To inspect Clean the Re-circulation system (hoses/check-valve/screens) you may have to flip the bracket of the ignition)
on the same side as your ignition packs/ coils are you see a few thin hoses running remove one by one!!
(so you don't mess up the order)
There's are "dog-bone" shape covers and a screen behind it check & clean as necessary (also clean the internal passage in the cover)
823715.pdf
check on page 26
