Tallboy610
- Aug 17, 2020
- 4
Hello all,
I bought a 1975 johnson 25 hp model 25R75B. Filled up metal tank and took it to the lake. Drop the jon boat into the water, motor fired up and idle until I returned from parking the truck and trailer. Ran fine on the water until you slow down and proceeded to die but would start back up and returned home to clean the carb. Needless to say, I have cleaned the carb by pulling out 3 metal plugs and soak in Acetone. Reassembled card with rebuilt kit added new fuel line and in line filter. Motor started in tank and idle for 10 minutes with a little throttle. Took it 5 miles to the lake and now it will not start. Disconnect kill switch still same result.
Compression 135.
Point gap .020
Plugs Champ J4C and gap at .030
Spark jumps to .50
Pulling hair out is and understatement considering my arm is still attached to my body from trying to start motor. Any help is appreciated. Thank you!!
Compression 135.
Point gap .020
Spark jumps to .50
