swvabassangler
- Aug 18, 2020
- 5
I have 1998 Johnson Fast strike 175 model be175glecd on 98 Triton tr19 that has been giving me problems for a while. I have owned the boat a few years. At first the boat would run in high 50s and turn 5600 to 5700 rpm with 24 pitch raker prop. The boat keep getting slower and slower losing rpms. Now the boat will only turn about 4800 rpm and run about 44 mph with a 23 pitch prop. The boat starts fine, idles fine and runs really smooth. Don't know much history on the boat. Vro was removed when I bought so it is premixed. Also purchased an Easytimer and checked the timing which was correct. Here is parts that has been replaced with oem parts so far.
New power pack
New stator
New coil packs
New plug wires
New optical sensor
Rebuilt carbs (high speed orfice was swapped to new bowls)
New carb bowls
Rebuilt fuel pump
New fuel lines from tank to engine with new bulb
New thermostats with springs
New throttle cam roller
New timing wheel (broke old one getting it off)
Also I decarbed the engine with sea foam deep creep.
I done compression check on cold engine and here is the numbers (don't know if gauge is accurate)
Passenger side top 95
middle 90
bottom 85 (was 80 first time and 85 the second time)
Drivers side top 105
middle 100
bottom 95
So I pulled the head and didn't see anything wrong with piston or any scoring on the cylinder walls. The pistons had very little carbon build up and the head had almost none. I have pictures but unable to get them to load (was getting "uknown error" message). The head o-ring wasn't tore.
Is there anything this could be other than rings? Maybe a reed? Maybe head o-ring? Thought It was odd that one side was good and other side was low.
New power pack
New stator
New coil packs
New plug wires
New optical sensor
New carb bowls
Rebuilt fuel pump
middle 90
middle 100
bottom 95
