Hey all,
I have a 1974 Glastron V-254 Caribbean with original dual Ford 302's I/O's that I recently acquired. It is a fairly rare boat. Seeing as the Volvo 270 outdrives on it lack any trim and as upgrading it to Volvo 290's, 290dp's, or any other volvo product is going to be 2-3x as expensive as mercruiser, I have a strong desire to convert the current setup to Mercruiser outdrives. As well as that, it seems like Volvo 270 parts are relatively difficult to find. I am located in the US near the great lakes.
I know that my 302's (that may be upgraded to 351w's in the future) are essentially the same as certain mercruiser I/O engines from that time such as the 888. However, Mercruiser hasn't used Ford's for a long time since then.
The motors were bought by Glastron in the 70's and taken to their factory where they "Marinized" them before putting them into their new boats.
My goal is to keep the engines on it as is for now, and swap/upgrade out the volvo 270 drives with a Merc product. I would like to go with the latest model Bravo drives I can, but I'm not sure about reliability vs Alpha drives. Not a deal breaker.
I also realize that shifting will be different. The current setup is hydraulic actuated shifting, so hopefully this isn't too much of a pain. Also has hydraulic steering.
Additionally, I know that there are adapter plates out there for this purpose for $600-$1500 each.
1. How much would I need to swap out if I had the transom adapter plates? What about Alpha vs. Bravo Drives? I'm assuming I would need to pull the engines from what I know, and this may be in the near future for performance reasons. Or would it be possible to reuse the Volvo inner transom adapter plates in place? Would I need to worry about adjusting the motor/motor mounts to account for the new mercruiser drive?
2. How reliable are Bravo II/III drives? Any maintenance cost differences besides the props being a little more expensive?
3. What drive would you recommend for around 300hp per engine in the future?
4. For the $1400 it's going to cost in a set of transom brackets, would it be more worthwhile to just get the transom rebuilt with something that doesn't rot? Not sure about me doing a transom rebuild vs having a small dry dock or someone similar do it. My dad does have fiberglass auto body repair experience, so it shouldn't be too hard for him to translate those skills into transom replacement help if it comes to that.
5. Additionally, while the current transom is super solid, I have some worry about it being too thin. I've read some threads in other places that talk about potentially needing to add thickness to the transom when converting from Volvo to Merc, but I'm not sure if that applies in my case. The last measurement I read was 2" - 2 1/8" required thickness. I don't know what my thickness currently is.
