I need to replace a leaking outter shaft seal on my 2004 Bravo 3. I purchased the boat new and it's only been used in fresh water, has low hours and no significant corrosion.
I bought the bearing carrier removal tool and used an 18" breaker bar along with 225 lbs. of personal love and no go! Tomorrow I'll try heating the housing with a very hot hair dryer and I'll get a piece of heavy wall pipe to use as a cheater if needed. Are there any other sage words of advice to break the bearing carrier loose?
Thanks in advance.
Brad
Thanks in advance.
Brad
