I have a 2006 regal 2650 with a 5.7 GX Volvo penta engine. I had the boat into the mechanics for a blown out freeze plug. They ended up putting the port and starboard freeze plugs back in and changed the water pump. When I got the boat back to the house, when I turned the key to the on position I got a loud alarm noise that wouldn’t go off. I called regal and left a message for a representative to get back to me. I brought the boat back to the mechanic, and he put it on the laptop, no error codes were thrown out. He diagnosed it as a faulty alarm and ordered a new alarm. Meanwhile I got a call back from regal, they said the only things alarmed are the oil pressure switch, the temperature pressure switch and the low outdrive gear oil and lastly could be a faulty alarm. When I called the mechanic to check if the part came in, it was in, I had told him that I spoke with regal and told him about the four alarm possibilities, he told me that Volvo penta only had that outdrive low gear oil alarm trigger in one model only available for two years and it was a complete failure and mine was not that model. He then reiterated that there were no codes thrown. I brought the boat back yesterday and texted him today and he said he put the new alarm in and that it didn’t take care of the problem and The alarm is still sounding and he will get back on it. My question Is, is it possible that either the oil pressure or temperature sensor switch is bad even though the computer did not register a fault code for them. Is there a low gear oil alarm trigger? When I dropped the boat off last, I did ask him if before he put the new alarm in can he check the gear oil, which he replied I already told you your boat does not have a low gear oil alarm. So I can see this getting crazy with hourly diagnostic fees so I’m trying to see what you might think. The only other thing I know of and doubt this is it but not too sure, when I got the boat back when it was last winterized, the ignition switch in the off position is now at the 1 o’clock position and not at 12 where it was when it first went in. Could that out of position switch touch maybe a ground wire or something? Latest update was that he called Volvo technical support ( he is a Volvo penta dealer) and gave them the serial numbers of my computer and another boats computer To see if they are identical to swap them out and see if the alarm goes off. ANYONE HAVE ANY CLUE WHY THIS ALARM IS SOUNDING. It is under the dash at the helm. He said he did also take the wires off both the oil switch and temp switch. I need answers. Please help. 2006 regal 2650 5.7 Volvo penta GX-i engine.
