Evinrude 200 - Won't Lower
trcsooner
My Evinrude 200 will raise, but not lower...
The electronics seem fine, I can hear it trying to lower, it just won't.
I've filled the trim/tilt fluid with the motor fully raised.
I've tried bleeding the air, but it still won't lower...
Obviously, I can lower the motor "manually".
Is there some way to "bleed the air" that I may not be aware of? Any other suggestions?
Thanks
ThomW
Have you tried switching the trim relays to see if the problem moves with the relay?
