Hello All,
Thanks for taking a look at my question.
I have my alpha gen 2 drive split to do an impeller service. The surface where the two drive halves meet as well as areas under where the water pump housing sits, has some paint peeling/peeled off.
I would like to know what I need to do to the surfaces before putting the water housing on and the drive back together.
Do I scrape, sand, prime, paint? Flake off loose paint and then use gasket sealant? or clean and use grease? some combination of these?
Thanks for you time.
