stevez9one6
- Sep 3, 2020
- 8
1990 bayliner 1990 force 50. Boat sat for a few years. My first boat . It needed some work but I thought it would be fun. Got it running. did full carb kit with main inlet. Re did fuel lines , clear so I can see its getting fuel. Getting spark both cyl. Good enough to fire first click and it kicks right away in gear. Just won't go over 11ish. I recently noticed sludge comming from the drain hole near the lower unit bolt. I dropped the lower unit this weekend and saw it was getting gear oil into the water pump area and thanks to a post, replaced a bad seal. Would that cause it to be slow? I refilled it. Ran it for a while. Dropped it again to make sure I didn't see any more. I saw a old post for a similar issue, but here it goes. Thank you to The Force power
