Horigan
- Jun 12, 2016
- 707
I'm having an issue with my OMC/Volvo engine water temperature sensor reading about 35 deg F too high. I've confirmed nominal temperature at the sensor with an IR gun (150 - 160F once warmed up). I've also confirmed the IR gun is reading accurately via a different temp probe. I've replaced the sensor twice and the dash gauge still shows about 35 degrees higher than the actual temperature.
An additional issue this is creating is that the ECM is seeing the erroneously high temperatures and it is triggering the SLOW (limp mode) system when the thermostat initially opens and I get a brief 25 deg overshoot as the thermostat is opening. The combined brief temperature spike, plus the sensor high reading, is triggering the SLOW mode, but this quickly gets resolved as the thermostat fully opens and the initial temperature spike is passed. Note that I have a half closed cooling system.
I've replace the thermostat twice and confirmed proper operation before installation (confirm initial opening at 160F and full open at 180F on the stove). So far I've checked continuity from the sensor to the engine harness and the wire reads good with no shorts to ground or high resistance. My next step is to check resistance from the engine harness to the gauge, then check the temp sensor wiring to the ECM. I have the OMC shop manual, so I'll need to review the wiring diagrams to the ECM. The specific sensor wire is pretty buried.
Have any of you run into this issue and can point me towards a likely area to investigate first? If my initial wiring checks don't find anything, I'll likely just buy another sensor and try that again. I've tried to find a resistance verses temperature chart for these sensors, but haven't been successful so far.
Thanks in advance for any inputs.
