I picked up a 16.5ft Vanguard boat this summer that has a 65hp Evinrude on it ran good then 10 min into the first sail I lost spark on the lowest cylinder, we trouble shooted on the water by swapping coil packs, spark plugs, and wires but problem didn’t follow still no spark on lowest cyl. Took it home and fixed a bunch of little things thinking it could be the cause but no luck. Narrowing it back to the power pack so I replaced that and the boat worked great for 10 min again and then lost spark on the lowest cylinder again. I’m thinking timer base is bad but don’t wanna throw a bunch of money at it without knowing the actual issue, I had also put a new rectifier on it because the original one did not work when I tested it so If anybody could shed some light that would be greatly appreciated! Thanks.
