Replacing my marine radio, same boat
Status
Not open for further replies.
JGator
I'm replacing my marine radio due to failure. I have a MMSI number in the current radio. Will I enter this same MMSI number in the new radio? Same boat, new radio.
TIA.
mike_i
Ensign
Yes. What are you going to do with your old radio? If it is going to be used by someone else it needs to be reset by a authorized tech.
JGator
Thanks, the old radio is toast.
Kyman53
Hi while talking about radios, I have a 89 Alumacraft flat bottom jon-bass boat with 40 hp outboard motor, that has a front and rear deck, Under rear deck where a seat seat would be is two 12 volt batteries one for outboard motor the other for Trolling motor wired to a two phase charging system. I am wanting to add a third battery up front to driverside. Want to build a 4 to 5ft box and have battery in it in battery case for all electrical lights, fish finders, and stereo would this be ok to fix it like this?
GA_Boater
What a hijack!
Closed.
Status
