CarlCioffi
- Apr 5, 2016
- 20
I have a 115 johnson that has recently had the carbs rebuilt, new plugs and wires. The fuel pump has been replaced with a pump that has no oiler so the gas has to be mixed. The motor runs fine except if I try to set the proper idle is eventually pukes. I've only been able to run it idling at around 1100 rpms. The rpms go down after a while but then back up however it does not puke on me.
