I'm trying to remove the sea water pump and the intake has this fitting with a spring loaded something on it that pulls up in to a second position. You can sort of see the one leg of it in the pic. At first I though it could be a quick disconnect in the middle but that doesn't seem to be the case.
Also, there's got to be an easier way to pull the intake hose off because I've been wrestling with pulling the hose off from this fitting.
