Freeridr22
- Oct 20, 2020
- 4
Hello I have a 1979 mark twain trihull with a 90 hp mercury 2 cycle ADI 6 cylinder. The original wiring in the throttle control is trash. Also the 5 terminal ignition switch marked A B S M M is broke off. I am changing the wiring in most of the boat as it is not safe. I rebuilt the mercury throttle and I am happy with not needing to replace it. However, it does not have a laynard kill switch and I want to add one to the dash. Also I want to move the ignition switch to the dash as well since I have changed the seats. The problem arose when I obtained a new ignition switch. It is a Sea dog Line 420365-1 Three position ignition switch. This clearly hasonly the Battery Solenoid and Ignition. I am aware of the Ms on the other as meaning magneto and have read much on this topic but I am very new to the boating world and only have diagrams, youtube, and forums to combine with my automotive knowledge. Finally, my question. Can I use this ignition switch, on the dash, by connecting the correct wires from the old ignition switch, and connect the two Ms to a laynard killswitch. Or is this switch completely incorrect for what I am wanting to do and have to order another switch with the 5 terminals. Thank you for any insight you maybe able to offer me.
