archbuilder
- Sep 12, 2009
- 5,697
by the way how do you prep for the powder coating? Media blast first?
Arch, not sure but I thought even masonry fire places still use stainless steel pipes inside. And it that is true for yours, then it needs maintained as well. IDKI need to do some work on my fireplace, but it is masonary. I picked up some fire set from one of my brick reps to point a few places.
WOW, didn't know they still existed. But for sure it is a well built fireplace. If you are worried about creosote build up, you could get a good light and either look up through the firebox area or climb up there and look down. I am sure there will be some build up, but probably not a dangerous situation. But it never hurts to check out.No this is an old school full masonary fire place with a clay tile flue and fire brick box..
Answer...well yes and no. If I get a stronger spring it will make the adjacent unit's turnbuckle move inwards a heck of a lot more. But as it sits, the turnbuckle setup merely slides into the block assembly and therefore if you need to use either of them, the other one can easily be removed out of the way. So it is all covered presently.Very nice on the S/S Stand ! But I do have a? Won‘t the turnbuckles be in the way of whatever you run through it ?
WOW Arch, that is certainly an ambitious spring plan there. I can honestly say, I'm really not a fan of heights. But sometimes you have to fight that fear and do things anyway. I will admit, the roof was built on two angles with my chimney. First was a mere 4 1/2" pitch (the roof over the screened in back porch) while the second was 7 1/2" pitch. A 4 1/2" is a cake walk. But the 7 1/2" certainly was not. And of course the entire chimney and the rest of the house is on the 7 1/2" pitch. Can't imagine a 12" pitch. But those pitches are only on our dormers...It must be the season of chimney fixing. I just repaired my parents chimneys. Yep two of them. One with a terra-cotta insert for the oil fired furnace, the other is older, all brick, no insert. Believe it or not, that’s the wood burning chimney. Both chimneys required that several courses needed taken down and laid back up. I convinced my dad that this spring the older chimney needs taken down completely and rebuilt around a stainless insert. That will be a fun project.
