Volvo Penta Throttle Only Button
Status
Not open for further replies.
Dwhite1960
I have a 2001 Crownline with the Volvo 3860580 side mount throttle control. The throttle only button was missing when I bought it, I have since replaced it. When I try to press it in, nothing happens I do not feel anything moving inside & the drive does not disengage. Is there a parts book for the control, or has anyone else had this issue?
Did you replace the bits under the rubber button cover as well, or just the button cover?
Dwhite1960
Thank You for responding.
I did also replace the white plastic stem that slides into the handle retaining bolt.
I can see what looks like a pin inside of that bolt, but the stem does not appear to contact it & the pin doesn't seem to move in or out.
Fun Times
Sounds like you may have an issue inside your Volvo Penta Control Mechanism which will be the part bolted to the back side of the controller.
Typically the control mechanism would come with a new control but it looks like I was able to find the
control mechanism part number for you....Below should be a compiled list of both sides for you to look over of your control unit.
3860580='ed 3888319 which now ='s 22928971 = https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313&_nkw=22928971&_sacat=0
Dwhite1960
Thank You
I now see why there is no breakdown as it is riveted together.
Part of my winter maintenance will be to pull that out & see why it's not functioning, and most likely order a replacement. Again thank you for the assistance.
Jrato14
Hi I know it has been years but where did you find this part
Status
