Does this look right? What is this spring called? Should there be a washer on the end? Also, my boat still won’t go WOT without it missing..it will make the motor stop and go with a big jump. It’s almost like it turns off and back on but when I go back to 3/4 throttle it runs fine. Then randomly when I go back to neutral and try to go faster, the engine seems like it has no power and want speed up. Could it be the stator? I’ve changed the fuel pump, spark plugs, power pack, coil packs and rebuilt/cleaned the carbs.
