Roadtrip76
- Jul 27, 2004
- 6
I have a 1988 Johnson 90HP motor with a strange charging issue. The stator is putting out 20 volts ac at idle, but I am only getting 12 volts at the terminal strip. Tach wasn’t working either, so I jumped the tach wire over to the stator side and it started working. This lead me to believe the regulator/rectifier was bad, so I replaced it today with a new one. Tach still doesn’t work after moving it back to the correct location and I still only have 12 volts.
