I bought it.. 1985 50hp
393Clevor
300.00 for the boat motor and trailer.. keeping the trim/tilt unit, motor and controls, cutting the rest up.. 105lbs in every hole the wiring looks awesome spark in all the holes, main output shaft seal leaks now that the motor is lowered and the gear oil can reach the seal.. it's got a little puddle under it.. Might just swap out the gear case with the one on the 60hp... I'll be cleaning the carbs and running it today.. I think it's going to be my motor for next season
The Force power
NICE!!!!
I would not just clean the carbs. but also replace the diaphragms (fuel-pump) that way there will be no more guessing or harm done.
Do a run-out on the shaft to confirm straight or bent?? and repair what you got :)
393Clevor
Only reason I bought it was for the PowerTran unit and it works awesome sounds strong when moving up and down... need to find out if there is any maintenance for it.. ya know fluid change whatever.
The Force power
I never had a Merc. that was equipped with power-trim. but on others.
I would raise it up and leave it there, check the next day to see if it dropped??
Maybe clean the motor?? check for a good seal where the motor meets he pump housing?
393Clevor
it was raised all the way up about 10 years ago and it hasn't moved untill I lowered it yesterday.. lol It's an aftermarket unit gonna have to go to their web site see if they have any info on these..
https://powrtran.com/shop/power-trim-and-tilt-50/
393Clevor
spend 2 minutes looking around and you can find anything.. lol seems those units use a electromechanical actuator, so no fluid to change..
