58 chris craft comet
- Nov 6, 2020
- 6
Brand new to this forum and brand new to 2 strokes.. My issue with my big twin is that there seems to be to much compression, if that's even possible. This motor sat for at least 30 yrs. on the side of my garage, covered, carb drained, cylinders fogged with 2 stroke oil and occasionally turned over by hand. I didn't try to start the motor at first, I did some basic maintenance and soaked the cylinders in ATF and 2 stroke oil. Every day I would give the rope a small tug, the motor was never ceased and after 3 days it hand pulled easily without plugs in.
As of today I have rebuilt carb, replaced impellor, rebuilt gear case, filled gear case with fresh gear oil, new spark plugs. My original pressure gas tank was rusted out so I'm just spraying gas/ 2 stroke oil directly in the carb. I have spark on both plugs. The first attempt to start I got combustion and it ran for about 10 seconds. The next time I got a back fire and now it will only turn over 1/2 revolution and is very hard to hand pull. If I remove both plugs it turns over very easily and hand pulls easily.
Tom
Tom
