Handyman72
- Oct 12, 2020
- 37
Gday all
Ok all electrics ohm checked
Carbys rebuilt
New coil
New plugs
New fuel tank,lines,pump
Points at 10 thou
WOT set 20 degrees with advance at stop,plugs out throttle at full
Throttlelinked
Timing sincd
Engine starts well and idles very slightly rough,engine revs well when in neutral, select forward or reverse (selectamatic) try to throttle up and engine starts to die,quickly disengage gear and engine will idle.select a gear again try to throttle up engine starts to die and stalls.
Engine then wont start for along time.
Primer bulb is not staying firm or hard.
Somebody please help as im really running out of ideas
Cheers
Carbys rebuilt
New coil
New plugs
Points at 10 thou
Throttlelinked
Timing sincd
Cheers
