MNhunter1
- May 12, 2014
- 1,078
Picked up a new project with a 1984 70hp Mercury hanging off the back with trim and an external (in the boat) pump. A bit different than the integrated trim I had on my 1987 Classic Fifty and 1987 35hp. What is the consensus on these trim units? Worth holding onto, or am I better off looking for something different, a CMC unit?
Looks like it requires a few more holes in the transom I’ll be rebuilding/replacing and takes up more space under the splashwell for the pump. Hull is also rated for up to 115hp, so not sure if I’ll be looking to upgrade down the road, but the hull is light enough that the 70hp should be more than adequate for my needs.
