Hi me and my son had to remove the lower unit on our 1986 merCruiser alpha 1. 260 to replace the impeller. We had a slight overheating issue. So after we find a few things that needs some work. We are left with a shifting issue. We replaced the shift shaft bushing and a couple of other things . Now we believe we found another problem. The brass intermediate shift shaft looks worn and the grooves the gear goes into also are worn out.
so we’re down to replacement of that. We have the lower unit off. Looks like no way to change it unless we also remove the upper unit. So with that said I can’t find anything showing that procedure?
We have looked in our merc book? Nothing shows it? Can’t seem to find it on the net either??? So the boat shop is 3to4 weeks out! Some help would be appreciated
I will post a picture of the part. Thanks Don
