1979 70HP Evinrude throttle problem
Edson19
Have a 79 70 HP Evinryde that will run at 1/4 throttle and then suddenly go full throttle. Stumped on problem. TYIA.
Faztbullet
Carb problem or suddenly running on all 3 cylinder from ignition problem. Need to investigate before running any more as if carb problm you have a cylinder not getting fuel and oil.
Compression test first the check ignition
Edson19
Runs on all three. good compression
Faztbullet
It is not running on all 3 when its acting up...when it jumps to full throttle is when all 3 are working. Need to test ignition and fuel system
oldboat1
Check the throttle linkages at the carbs and make sure they are intact. Additionally, make sure the remote throttle cable is secured, and the inner cable is not slipping.
