soulhawaii
- Apr 23, 2020
- 40
You re just seeing the timing light adding and removing ten degrees of advance hence why it goes to 10 BTDC with no advance in the light, and zero with ten degrees advance.To add, on my timing gun there's an advance option, when I set it at 10, with the pulley showing 0, when I set the gun to 0, the pulley goes to 10, on the right of the 0 mark, but everything I read online says BTDC is on the left when looking at the engine, not sure why I'm confused by this
Ayuh,..... On older motors the timin' tab was mounted on the block, which puts the Btc on the left,.....This will probably be a dumb question, but in the image BTDC is on the side where the 6 is correct? I ask because I need to see the timing to 10 BTDC but why would there not be a mark for 10 on that side, but one on the other side?
No base timing mode on a TB 4You re just seeing the timing light adding and removing ten degrees of advance hence why it goes to 10 BTDC with no advance in the light, and zero with ten degrees advance.
mist stock balancers have only TDC and what ever base timing is. So you use an advance light to program in ‘X’ advance, this will make the light flash when the tdc mark is at the pointer. Say you wantto verify you have 30 degrees total advance at 2500 rpm. Set the light for 30 degrees, this will offset the light to flash when tdc on the balancer is at the pointer.
as scott mentioned you likely have to set the ignition in base mode - required if you have a delco est or thunderbolt 5
Correct but there is on a TB5. Wasnt sure if you were just pointing out diff between 4 and 5, not sure if OP specd a year or ignition system, just wanted him to be aware of the need If he has EST or TB 5No base timing mode on a TB 4
Yeah, he didn't specify. Just so he knows he may or may not need base mode.Correct but there is on a TB5. Wasnt sure if you were just pointing out diff between 4 and 5, not sure if OP specd a year or ignition system, just wanted him to be aware of the need If he has EST or TB 5
