Volvo Penta 855932 Prestolite 7801A advance springs
bollerwagon
I am looking for the advance springs for my old AQ271C distributor and struggle to find them. original Part numbers seem to be 856249 or 855912 but those are nowhere to be found.
Assuming I am not the only one with this problem, did anyone find a suitable replacement?
kenny nunez
What happened to the springs? If they rusted away and you are still using points then there is a good chance that the rotor shaft is also rusted and abrasive which wears out the rubbing block on the points.
If your distributor is the electronic version then point wear is no problem.
I was a Volvo dealer for many years and never had to replace the springs but in your case you maybe you should consider replacing your distributor with a Mallory marine style. That way you can use the spark plug wires over.
bollerwagon
the distributor is perfectly fine, just the springs are broken. I am not really willing to trash it just because of a 5$ part.
No offence, but as I know the volvo penta dealers over here - I´d wonder if you´ve ever seen a boat older than 3 years... ;-)
kenny nunez
OMC also used Prestolite distributors along with Mallory. You might have some luck with the obsolete OMC parts dealers. Mercruiser also used the Prestolite distributor on some Ford engines until the late 70s.
I was a Volvo dealer from 72-03 Along with Mercruiser, OMC and Berkeley Jet also used Prestolite.
saskflyer
I have a 93 volvo penta 740b big block with a prestolite distributor, Pertronix makes a 8cylinder ignitor; part # 1589. Will this work in my distributor
bollerwagon
these are not springs, or do I get that wrong?
Why are you hijacking a thread?
Your distributor is already electronic pickup. You do not need anything that pertronix has for your distributor
Back to the OP. @bollerwagon there are 2 different springs in the AQ271c dizzy. That is how they got a knee in the advance curve. Do you still need springs? Or a complete dizzy?
itsathepete
Not a Volvo but I had an OMC with a prestolite distributor that had missing/broken springs. I got a set of springs and weights from an auto parts store for a few bucks. I think they were Mr. Gasket brand. I was able to find a pair of springs in the kit that gave me the proper advance curve. Might work for you
Lou C
Try marine engine.com, look up a similar OMC engine….
I have found a couple of spare Prestolite distributors for my old 4.3 V6 complete with the springs etc on eBay….
If you use aftermarket springs see if you can find a hot rod shop with a distributor machine (very old school) they may be able to check the advance against factory specs. Otherwise you can experiment with an advance timing light to see if those springs got you close. You want enough advance for good performance but not too much because that will cause engine damage.
bollerwagon
I still need those springs, the rest of the distributor works fine. Do you happen to know a specific product number or something?
Lou C
What you are going to have to do is search based on your engine/carb combination, so if its an AQ 271 I'm thinking it is a 5.7 with a 4bbl carb, correct?
I don't have part numbers you're going to have to look for parts for similar engines (OMC or Mercruiser) that used the same Prestolite distributor.
I did some looking around, these parts are very hard to find as you have found, it might be best to quit chasing ghosts and upgrade to an electronic distributor. I was able to find them for my old 4.3 4bbl a few years back, mine are still good though. The Prestolite had a lubrication wick in the distributor shaft and you could pull off the rotor once a year and put a few drops of oil on the wick, lubing the weights and springs. That's what made mine last this long!
If I really wanted to keep the points distributor, I'd get some aftermarket springs and an advance timing light and experiment, you might get lucky and be able to do it that way. Here's my Sears Craftsman timing light from the '80s no doubt. You have to run the engine at the specified RPM, set the dial to the total advance spec # and it should read zero on the timing tab.
itsathepete
I was able to get a pair of springs from this set that worked with prestolite distributor and matched the factory advance curve. It took a little trial and error and you need an advance timing light or timing tape on your balancer.
Lou C
There you go nice find.
I still have a pair of Blue Dot springs for my 1970 Ford 302 V8 from the '70s lol.
bollerwagon
3 years later, same problem again. But this time the bigger spring was a bit overstreched, for whatever reason. I´m thinking about asking someone to produce these as replacement. Is anyone out there who can confirm or correct these measurements?
Small Tension Spring ( a bit more rusty than the bigger one)
Wire Diameter: 0.8 mm
Overall Length (unloaded): 16.6 mm
Outer Diameter (of coil body): 7.1 mm
Inner Diameter of End Loops: 5.0 mm
Large Tension Spring (blue-ish color)
Wire Diameter: 1.4 mm
Overall Length (unloaded): 21.9 mm
Outer Diameter (of coil body): 7.4 mm
Inner Diameter of End Loops: 4.9 mm
both seem to be ferromagnetic
I am not a technician, if anyone has an idea what dimensions should be called alternative - let me know.Feder 4.jpg
since the ignition module in the distributor is something like $600, I would simply go to a different distributor. I have a prestolite under the bench which probably has the same spring issue. replaced it with a Mallory YLM-624 years ago. The spring kit has gone thru a few part number changes including 855912 and 856249. all of which are NLA
volvo themselves went to the Delco Voyager EST for many years.
I went down a rabbit hole of just searching "prestolite distributor springs" and there are hundreds of threads for people trying to find them on hundreds of sites.
mostly old ski boats that used the prestolite dizzys.
here is a set listed for the Chrysler motors. https://www.trojanboats.net/zencart/index.php?main_page=product_info&products_id=1928 there are 3 sets left.
bollerwagon
This should be the map for the AQ271C Distributor.
Would be nice if someone could check his map and if compliant, measure the springs so they can be rebuilt
pretty much same as the delco EST or any of the marine distributors. 1747866038219.png
bollerwagon
Looking at the workshop manual I tend to think that there are different springs used:
2025-05-23 08_40_36-Volvo Penta AQ211, AQ231, AQ271, AQ311, BB231, BB261,500, 501, 570, 571, 5...jpg
Although only 2° difference in idle, there is a bigger difference at higher RPM. E.g. :
- 501B has 20° B.T.D.C at 2.000 RPM already,
- 501A has 14° B.T.D.C at 2.500 RPM.
Might be looking at it wrong, but this suggests that we have different curves for the engines.
But I do admit that there seems to be a one-fits-all solution since VP replaced all disitributors with one single part number meanwhile.
The distributor has a 20 degree advance
You want 34-36 degrees of advance all in
I swapped to a Mallory 10+ years ago because the prestolite isn't supported and the ignition module was over $500
The Malory is set with 24 degrees of advance and my base timing is 12 in the BBC, was 10 on the SBC (AQ271). Ran both the SBC and BBC with the same Mallory distributor.
The 5.0 liter you're now posting specs for needs a little less total advance, usually with different base timing, however the 14 degrees for the 501A was quickly changed to 20 degrees.
Don't wrap yourself up with a 40 year old document on a distributor that hasn't been supported for 20 years.
I would personally buy a used Malory YLM-624-AV or a new Delco EST if I was in your shoes . I would recommend a new Malory, but they sold the marine distrutors to Sierra now and the price doubled. So a $75 used one with a new cap and module.
If you want my old prestolite dizzy for some reason, it's yours for the cost of packing and shipping. But I changed it because it isn't supported
Lou C
Yep can’t get those modules for the Prestolite BID (electronic) units, the earlier ones with points & condenser can still be serviced. I have spare springs, points plate etc for mine…I think I might have bought the last of those in the inventory!
