I just bought a Glastron Futura 205SL. It is very clean and has been garaged it's whole life. The guy I bought it from says That at the end of last seaon, last time he took it out that it got really hot under load and that the starboard exhaust manifold is what is really getting hot. So I believe the water blockage is there. I know these commonly break down with age and is a fairly common issue. He did replace the water pumps with no change in the heat.
My question is, normally does only the riser go bad or should I replace the exhaust manifold and riser? Luckily this boat is designed with a lot of room around the engine and it looks like I can get to everything fairly easily. Are there any tips or tricks to removing the manifold? Thank in advance.
