After spending the entire winter disassembling and reassembling with a few new parts I have finally got it all together and running way better. Among the defects 2 broken coil packs, 1 broken ignition wire, wrong spark plugs, missing cam roller, loose timing linkage. I only broke 1 bolt the whole time. My issue now is purely mechanical. My throttle linkage is clearly not correct at wot the linkage binds up against the throttle plate shaft. I can't find a diagram that shows what I have.
View attachment 356063View attachment 356064
