I have a Marina doing a repower to my 28' Regal. They built out the new motor on the floor before installing and ran it about 20 minutes and it ran fine. After the install when water testing They ran the boat another half hour. The motor ran fine but the boat was leaking. This boat also has a new outdrive with all new bellows and gimble bearing. They removed the motor and outdrive and found that the transom assembly was bad with corrosion and a few broken bolts. They then installed a new transom assembly and while reinstalling the motor they dropped it damaging a large part of a stringer that the motor sits on that they actually tried to hide from me. Also broke one pully, and bent another one one the motor.
Now that they have the boat back together and running the motor makes a random knocking noise. It's not a constant knock and doesn't change at any rpm just a random knock every few minutes. This motor is brand new and successfully ran twice with no problems, and now makes this knock noise after being dropped and dropped hard enough to do physical damage to both the boat and motor.
What could be wrong with the motor, and what are your thoughts knowing it ran fine twice before being dropped that the damage to the motor is a result of being dropped?
Any and all your thoughts would be greatly appreciated. I've spent close to 20k one this project, and this mess is making me sick. I need to know what my next step will be when I approach the owner of the marina that's been working on it. Also, they've had the boat for well over a year maybe closer to two years.
Thanks for any and all of your help.
