Crownline290
- Jul 27, 2020
- 15
I have a 2003 Crownline 290 with twin Mercruiser 5.0L carbureted 220hp engines with Alpha One drives.
Been having an issue with my starboard motor for quite some time. The motor runs great for about 20-25 minutes, and then it randomly shuts off. It will then start, rev and shut off. The next morning as soon as it is cool again, the motor will start right up again like nothing ever happened.
I have replaced the sensor under the distributor cap, the coil, and just changed the fuel pump today. Was hoping that would fix the issue, but I just took the boat for a ride and the same thing happened.
While it was in the no-start condition, I tried bypassing the oil pressure sensor and it still wouldn't start. I then disconnected the wire on the shift interrupter switch and it fired right up. Oddly enough, unless I bypass both the oil pressure sensor and disconnect the shift interrupter switch, the boat won't run.
What gives?
I'm thinking of replacing both parts.
Any advice is much appreciated.
What gives?
