Projectmach1
- May 17, 2021
- 13
I'm doing a full resto on a 92 Mach1 Concorde with a Mercruiser 7.4/Bravo 1. I knew the engine had some sort of water intrusion from the start due to milky oil but I was hoping it wasn't something too bad. I got the engine out of the hull finally and found out the block has a huge Crack on both sides which were hidden by the exhaust manifolds. The block casting is 10114182 which I found to be a 91+ GenV 4 bolt main. I found a guy selling a pair of 454 blocks a few hours away, one is from a car/truck and one from a boat. His casting number is 14015445 which I found to be a 78-90; 2 or 4 bolt main.
I'm fairly new to the GM engine game so my question is, are either of these blocks usable? All he is selling is the block and bottom end internals. I would of course be taking everything out and having it cleaned up with new cam bearings and marine freeze plugs. If the older blocks are usable I'd love to jump on this since he's only asking a few hundred per.
